Post
by Moeregaard » Tue Oct 07, 2008 10:09 pm
This is a very common problem--and not a fun one. Liberal amounts of penetrating oil, some heat from a propane torch, and a lot of patience usually works. Be careful with the latter as you only have to heat things gently to enable the penetrant to work more effectively. You're de-mating two tapered steel surfaces, so these things can really stick together. When you have everything cleaned up for reassembly, some copper grease on the mating surfaces will make things easier next time.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
