#1 Performance air filters
Posted: Sat Jan 05, 2008 8:16 pm
by harryetype
I'm trying to find a good alternative performance air filter for a Triple carb set up on my E-type 4.2
I might even go for ram pipes, has anyone any good suggestions?
Harry
#2 Been there, done that
Posted: Thu Jan 24, 2008 3:31 pm
by chuckgoolsbee
My car arrived into my care with K&N "pancake" filters.
The engine was freshly rebuilt... and it died a miserable death about 10,000 miles later. I do NOT attribute its death to the filters, but I resolved to revert the car as much to stock as possible. It took me forever and way too much money to acquire the stock filter assembly on ebay. I was within a few weeks and a couple of stray parts to having it restored and back on the car when I was notified by SNG that I had won a photo contest of theirs! The prize was a parts voucher. The value of the voucher matched the cost of their ITG "performance" filter, so I figured "what the hell!"
http://chuck.forest.net/jag/KnNremoval/
The first thing I noted was that the car's torque curve no longer flattened out in the midrange. That was a surprise. The K&N's are *supposed* to be a performance filter, but in reality they hindered performance. Go figure.
So based on that, I'd stick wit your stock setup, or something that emulates it like the ITG one.
The K&N's looked cool, but they were basically worthless in my opinion.
Posted: Thu Jan 24, 2008 7:33 pm
by Car-Nut
chuckgoolsbee you have PM
Posted: Sat Jan 26, 2008 4:45 pm
by Chuck Anderson
Hi Harry,
I've had great success with ITG air filtration systems. When I was running SU's, I used their system that was specifically designed for triple SU's.
I now use their system that is designed for triple Webers, which I have adapted to my EFI system.
Hope that helps.
Cheers,
Posted: Sun Jan 27, 2008 5:25 pm
by Car-Nut
Hi Harry,
Is this what youre looking to build an air filter system like this???
Posted: Sun Jan 27, 2008 7:03 pm
by harryetype
Thank for all your advice the ITG was the system I had in mind.
Harry
Posted: Mon Jan 28, 2008 9:31 am
by Car-Nut
Posted: Sat Mar 01, 2008 5:56 pm
I use the ITG Air Filter System to good effect:
http://www.rob-beere-racing.co.uk/induction.html#filter
Remember you will need to change the carb needles (U0 I seem to recall) if you go for these type of filters or any open trumpets. Rob Beere includes the correct ones with his ITG filter set.
David
