#1 New carbs for v12???? HELP!!!!!
Posted: Sun Jun 09, 2013 7:01 pm
Hello everyone.
As some of you know I'm trying to get my 73 etype up to scratch (and reliable) in time for my wedding on the 27th July. I have got the ignition issues, valve clearance issues, electrical issues and cooling issues all under control now however.......... Carburettors! It is clear to see that he carbs have had a whole range of attempts to bring them under control, this I clear because of the twisted mess that they've been left in. All I have done to date is strip and rebuild the carbs with diaphragms and gaskets, this has been enough to get the car running and useable while I sort the more pressing issues. This weekend I've stripped and carefully inspected the carbs and I was pleased to find some obvious issues that would explain poor running. Unfortunately the issues look like more than a clean, rebuild and setup can cure.
From what I can see the air filter bolts have been over tightened, they have subsequently driven themselves into the carb bodies and cracked two of the main casings. This leaves me with some questions for you all as to what I should do next. I could source some used main bodies and undertake a full rebuild myself and try and get this done in time to use the car on my wedding day, or...... I could purchase a brand new shiny set of carbs or a set that has been rebuilt, this will clearly cost a small fortune but (depending on quality) should seal the end of my carb woes and will be the quickest way to get me up and running. I would be grateful for ANY advice, I also have very little idea of what to expect in terms of cost, time frames and in particular who to go to for new/rebuilt carbs. Who is the most reliable and best value for me to approach? I've emailed some companies I've found online but not heard anything back yet.
Thanks all for your help.
Marcus.
Marcus.
