V12 Fuel flowing between Carbs
SESH
#1 V12 Fuel flowing between Carbs
Post by SESH » Sun Jun 09, 2013 9:01 pm
Hi, I have just renewed the connecting pipes between each set of strombergs with a clear plastic pipe and have just noticed when starting with choke and running at about 2000 rpm that fuel is flowing through the connecter pipes from one carb to the next. I thought these were breather pipes, so is this correct or is something wrong. Thanks for any input.
Mike
1973 Jaguar E Type Series 3 OTS Signal Red
1968 Proteus Jaguar C Type Ecurie Ecosse Flag Blue
1963 Triumph TR4 Signal Red
2020 Mustang Bullitt Highland Green
Post by PeterCrespin » Mon Jun 10, 2013 2:38 am
It's normal.
The choke cable only goes to one carb each side because only one carb each side has, err, a choke. Actually it's extra cold-start fuelling not choking of the air, but still. The connecting tube allows both carbs on each bank to have the extra fuel from one enrichment valve. The tubing was originally black so you didn't see anything.
SESH
Post by SESH » Mon Jun 10, 2013 11:26 am
Thanks Pete, Worry over !! :roll:
