My dad's E-type has got this US spec exhaust manifold with a connection to the inlet.
This winter we're planning on fitting a set of triple SUs and obviously, these bits have to be removed.
So, either, I could block the hole in the exhaust manifold with a big plate, or I can get a new manifold. I take it I only need one of them, although buying just one could prove difficult.
So the ultimate question is....
Can I just get a set of cast manfolds from somewhere?
Did these change over the years? The car in question is a 1.5 4.2
These?
http://www.ebay.co.uk/itm/JAGUAR-E-TYPE ... 3f28d6f000
I've been thinking about getting a proper tubular system, but I like to keep the noise down.
Cast exhaust manifold Q
#1 Cast exhaust manifold Q
68 1.5 FHC, 65 4.2 FHC, 72 MGB GT, 6 Minis, 71 Escort1300GT, 65 BMW Neue Klasse, 62 Volvo P1800 and a 205 GTI
Yes get a set of cast manifolds. Check around on price; for example SNG Barretts have them for UK pound 125 each.
On dyno the tubular headers have been shown to not be as good with the E Type engine as the standard cast ones.
Be aware that regardless of what they are "enameled" with the coating frequently cracks and falls off..
You don't need to replace the manifold except for looks. There is no hole that needs blocking - just a flat area where the crossover sits.
Remember that just fitting triple SUs won't be enough by itself - you'll need the matching distributor with correct timing curve and vac advance.
There has to be a hole in the exhaust manifold somewhere? What is the point of the big pipe if not? I've got a 123 dizzy which I hope can provide the correct advance curve. Very anxious to get rid of the clapped out Str?mbergs though ;)PeterCrespin wrote:You don't need to replace the manifold except for looks. There is no hole that needs blocking - just a flat area where the crossover sits.
hot air from around the exhaust manifolds, not exhaust gases !
johnney
1968 FHC series 1
1E21862
1968 FHC series 1
1E21862
Seriously? What on earth is the point of this as long as the inlet is heated?johnney wrote:hot air from around the exhaust manifolds, not exhaust gases !
I should be happy though, that's ?150 saved :)
Because the exhaust manifolds heat up a lot quicker than the coolant water, which makes all the difference.
johnney
1968 FHC series 1
1E21862
1968 FHC series 1
1E21862
Indeed, I can appreciate that.
I guess there is nothing stopping me from ripping the dead weight off then. I want the inlet charge to be cool as ice :)
