Rebuilding rear hubs
Simonpfhc
#1 Rebuilding rear hubs
Post by Simonpfhc » Sat Aug 24, 2013 10:47 am
I'm rebuilding the rear hubs on my 62 FHC. I've finished the actual hubs/bearing/end-float part without issue and have now started on the outer fulcrum.
I've fitted the new races which are fully home, and when I do a trial build-up, I find I need about 65 thou in shims between the two sleeves to get the correct pre-load. Everything I've read suggest that I should only need just a few 4 thou shims?? Both of my hubs seem to need this large shimming. I've double-checked that I have all the correct items and nothing seems amiss.
Anyone else experienced this?
Cheers.
62 3.8 FHC
91 Porsche 928GT
Durango2k
Post by Durango2k » Sat Aug 24, 2013 7:15 pm
Are you using new tubes ? They may be shorter.
Are the races REALLY fully home ? Both ?
Carsten
Simonpfhc
Post by Simonpfhc » Sat Aug 24, 2013 9:37 pm
Hi Carston,
Thanks for the reply. Yes, I'm pretty sure the races are fully home - but I am going to double check anyway. The four tubes are all the originals and there is no sign of wear. I have measured them and they are all identical in length. All I can think of is that the bearings are machined slightly differne to the originals.
Either way, if I can't spot any errors, I am going to need to get two 60 though shims made up :-(
Cheers.
62 3.8 FHC
91 Porsche 928GT
Durango2k
Post by Durango2k » Sun Aug 25, 2013 8:58 am
Hi Simon,
I may have - from an XJ6- the long tube which this one uses.
The E-Type has 2 tubes and shims in the middle, the XJ6 has a long tube and shims on the side.
Now, if I send you this tube you could cut of a part by yourself and file and fidle until it is better then 60 thou.
Fit this "home-made spacer" on the OUTside so that still the shims would be between the E-Type originals, and then your?e done.
Only thing is that the cut has to be 90 degrees and accurate as you can, cause else the force would be on a part of the "spacer" and may deform it with time....
Carsten
Simonpfhc
Post by Simonpfhc » Sun Aug 25, 2013 9:45 am
Hi Carsten,
That sounds like A good idea - i'll take you up on that offer. PM on it's way.
I would also be interested to see what the length of the XJ6 tube is compared to the pair on the E.
Really appreciate your help :-)
62 3.8 FHC
91 Porsche 928GT
Durango2k
Post by Durango2k » Sun Aug 25, 2013 10:42 am
As written- mail me your adress + you?ll get that for free.
Carsten
Post by PeterCrespin » Sun Aug 25, 2013 9:54 pm
Simon, are your replacement bearings Timken brand? These are machined very accurately and would normally go together with the same shims on checking. Other brands, especially no-name or Chinese cheapos, not so.
Durango2k
Post by Durango2k » Mon Aug 26, 2013 4:59 am
... just seen it?s a 3.8 in this case:
The INNER LOWER fulcrum tubes (where the 2 needle bearings run on) are different from the 4.2.
Be carefull, buy the correct kit there - no real price difference on ebay.
Carsten
neil4444
Post by neil4444 » Mon Aug 26, 2013 7:29 am
Hi Simon,
I rebuilt hubs recently on my 62 OTS and as per your expectations I only put in a few 4 or 7 thou shims. However, I did initially get a bunch of rogue readings from my dial gauge as the way I had mounted the hub carrier & dial gauge in/on the vice to take readings was allowing the carrier to rotate slightly as I raised/lowered it. This threw readings out quite wildly. Once I had prevented rotational movement I was able to get correct readings & I ended up putting pretty much the same shims in as I initially removed. I purchased my bearings kit from Hutsons.
Alternatively, and certainly without meaning to offend, are you sure you're reading the gap the right way and it's not a case that you need to remove rather than add shims ?
Neil
Simonpfhc
Post by Simonpfhc » Mon Aug 26, 2013 8:11 am
The bearings were sourced from SNG and are not Timken. They are branded J5N and type 03062. This may account for the issue??
When built up, I had to use 70 though of shims between the two spacers to get any movement at all - and then only about 5 thou. This is exactly the same for both hubs. So it looks like I need 64 thou to get the right pre-load.
I am going to double-check everything one evening this week.
Neil - thanks for that tip re rotation. I did notice that the readings on the dial guage varied if the hub made any rotational movement at all. I didn't try to lock that movement, just was very careful when raising the hub :-)
Cheers.
62 3.8 FHC
91 Porsche 928GT
neil4444
Post by neil4444 » Mon Aug 26, 2013 8:41 am
I guess it must be just down to the bearings/shells then. Can't see a problem provided tolerances are okay & you can still get it into the wishbone.
Cheers,
Neil
Neil
1962 S1 OTS
1967 S1 FHC
Simonpfhc
Post by Simonpfhc » Mon Aug 26, 2013 4:10 pm
Actually, that's a good point Neil - i will test fit the wishbones at the same time to make sure that it will fit OK!
Cheers.
62 3.8 FHC
91 Porsche 928GT
wol916
Post by wol916 » Mon Aug 26, 2013 6:10 pm
I had exactly the same problem with a set of bearings from SNG they are not the same speck as the Timken ones, I got some Timken and everything was fine. I informed SNG to prevent this from happening again and returned the incorrectly supplied bearings. When I called to see if they agreed with my findings they said they had not received the bearings and have obviously not made any changes. All a bit disappointing really this has made me very wary of what I purchase from them anything I can get direct from specialist factors I now do so, takes longer to source the parts but at least there is a goo chance it will fit without modification. :(
Warren
S1 FHC 4.2 OSB
Simonpfhc
Post by Simonpfhc » Mon Aug 26, 2013 6:55 pm
For the hub carrier rebuilds, i ordered everything from SNG - all bearings were Timken EXCEPT the outer fulcrum bearings! I may well order a set of Timken for the fulcrums and see what difference they make.
Cheers.
62 3.8 FHC
91 Porsche 928GT
wol916
Post by wol916 » Mon Aug 26, 2013 8:06 pm
The inner race sits about 0.4 of a mm further out on the non Timken ones and you can't get the wishbones on only answer is buy Timken. I got them from here http://www.bearing-king.co.uk/products. ... rch=timken good service price OK.
Warren
S1 FHC 4.2 OSB
Simonpfhc
Post by Simonpfhc » Tue Aug 27, 2013 7:00 am
Thanks Warren, much appreciated.
I will do a dry to check just in case the built up hub carrier can fit inside the wishbone, but I reckon it won't! At which point a set of Timken will be ordered and I will be sending the Jap bearings back to SNG.
Cheers.
62 3.8 FHC
91 Porsche 928GT
Simonpfhc
Post by Simonpfhc » Tue Aug 27, 2013 4:59 pm
Just did a test build and indeed the hub carrier with the Jap fulcrum bearings do NOT fit between the lugs on the wishbone. With a bit of force I could probably get them squeezed in, but really too tight - probably by about 60 thou!!
Timken bearings on order and Jap ones being returned to SNG.
Thanks for everyone's help. I will report back when I fit the Timken bearings.
Cheers.
62 3.8 FHC
91 Porsche 928GT
Simonpfhc
Post by Simonpfhc » Fri Aug 30, 2013 5:25 pm
OK, so I've now fitted the Timken bearings.......did a dry build and all is now as expected :-)
So the outer fulcrum bearings supplied by SNG are not manufactured to the correct tolorences. Also, i have been calling them Jap bearings - incorrect - they are in fact made in England and are Hoffmann. Either way, they are wrong.
I was quite surprised at the price difference between the SNG supplied bearings (?9) and the Timken bearings (?25), but hey, they fit!
Thanks for everyones input to this issue.
Cheers.
62 3.8 FHC
91 Porsche 928GT
