Removing bonnet panels
Simonpfhc
#1 Removing bonnet panels
Post by Simonpfhc » Mon Sep 09, 2013 2:23 pm
Hi all,
I've just finished stripping down the bonnet of my '62 FHC. Don't really want to attack the underside of the bonnet with a gas torch, so can anyone let me know the best way to safely remove all the glued-on brackets, or rather how to remove all the ancient beads of thick glue? There are 12 in total!
Cheers.
62 3.8 FHC
91 Porsche 928GT
288gto
Russia
#2
Post by 288gto » Mon Sep 09, 2013 2:52 pm
I used windscreen removing cheese wire, a heat gun and then this...
http://cdn.toolstation.com/images/13012 ... /10332.jpg
It's coarse enough to remove the glue but not attack the metal.
hope this is of some help.
Post by christopher storey » Mon Sep 09, 2013 5:54 pm
I have used a heat gun , and to scrape the residue off I use a homemade wooden scraper consisting of a chisel shaped piece of 2 X 1 . The cheesecutter wire is a good idea
Simonpfhc
Post by Simonpfhc » Tue Sep 10, 2013 5:09 pm
Thanks for your ideas guys, much appreciated.
Yes, like the cheese wire idea too! So heat gun and cheese wire it is then.
Cheers.
62 3.8 FHC
91 Porsche 928GT
Simonpfhc
Post by Simonpfhc » Mon Sep 23, 2013 7:46 pm
Ok, so I've now removed all the brackets that were glued to the underside of the centre section of the bonnet. All came off pretty easily in the end.
However, I now need to remove the two backets on the underside of each wing. Straight away they looked different; very closely attached to the wing ( no gap, completely flush) and no sign of any glue. So are these brackets spot welded?
Cheers.
62 3.8 FHC
91 Porsche 928GT
Mike L
#6 Bonnet fitting
Post by Mike L » Mon Sep 23, 2013 11:27 pm
Nope:
Glued on like the others.
There is ONE exception. The transverse stiffening rib at the rear edge of the main panel, This rib is spot welded and glued.
Mike L
Simonpfhc
Post by Simonpfhc » Tue Sep 24, 2013 3:59 pm
Thanks Mike, much appreciated.
62 3.8 FHC
91 Porsche 928GT
