God knows what it came off but when on the car the "easily removable oil filter cannister" was nested under the carbs with zero chance of getting it undone. In fact I had to remove the entire housing, but fortunately I had already decided this piece of crap was destined for the tip and I have an original filter housing ready to install. The madness does not stop there because they then had to cut 'n weld the oil return pipe to a jaunty angle to meet the hose.
Next they realised the new housing had five bolts holding it the block so the drilled and tapped a new hole to accommodate it. Finally they found the oil pressure sender would not fit so they fabricated a conversion piece to suit. Talk about a game of consequences. All this rather than spend ?80 with SNGB for a simple spin-off conversion kit that would at least allow you to remove the filter without dismantling half the engine
I am now ready to put the original style filter housing in place but all this bodging has slightly unnerved me so I need a sanity check that all is well with the mounting point (other than cleaning properly):
Specifically is that screw correct?
* There were two other things:
1. Worried about overheating they installed a secondary fan on the stone guard and inserted a modern in line electronic thermostat in the top hose. This had the effect of lots of cooling with the car at a standstill but significantly reduced air to the radiator when on the move - the secondary fan disrupted airflow :? The fan was alsao too far from the radiator to make any difference anyway. Must have taken them a day to fabricate and source the (expensive) components when a Coolcat fan and Otter switch would have been half the price and installed in an hour. It would also have worked!
2. Worried about Ethanol in fuel they (probably rightly) decided not to use the original in tank fuel pump. Rather than spend ?110 at SNGB for one of their new submersible pumps they opted for that hideous Facet fuel pump. This meant running fuel pipes around the wheel well together with associated wiring, sourcing and installing a pump mount in the o/s rear wheel arch and then finding the Facet produced way too much pressure for the SU's. A rather smart looking fuel pressure regulator was then installed next to the pump. The result was asthmatic wheezing from the regulator and the whine of a jet engine from the facet which runs permanently - not good in a FHC :x
Both of the above were remedied very quickly!
