s3 Brake Pulse
sprog
#1 s3 Brake Pulse
Post by sprog » Fri Nov 01, 2013 6:44 am
Hi Guys.
I Have recently taken over as custodian of an injected V12 s3.
Took it for a shake down run, (an automotive epiphany, what an awesome car) and noticed that when I apply the brake peddle pushes back on initial application then works normally.
Anyone seen this problem before?
Any ideas on how to rectify this issue would be greatly appreciated.
D COUPE
Post by D COUPE » Wed Nov 06, 2013 1:28 pm
I have come across this particular issue BUT before you get your hopes up
No one as come up with a solution. It is as if the pedal presses back on your foot before the brakes are applied. Anyone with a knowledge of this phenomena??
DC
ITS NOT WHAT YOU DRIVE ITS HOW GOOD YOU LOOK IN IT
ralphr1780
Post by ralphr1780 » Wed Nov 06, 2013 4:23 pm
Fellows,
Seems same issue as described in the running post "brake pedal kick back" in Technical / Ser 1.
I confirm having come across the same, and solved it!
Ralph
'69 OTS + '62 OTS - Belgium
sprog
#4
Post by sprog » Wed Dec 04, 2013 6:13 am
Thanks,
I Checked that out, will get a rebuild kit and pull the servo apart and check it.
D COUPE
Post by D COUPE » Fri Feb 21, 2014 6:14 pm
ralphr1780 wrote:Fellows,
Any one know where the above post as gone.
One of my winter jobs
thanks in advance
ralphr1780
Post by ralphr1780 » Sat Feb 22, 2014 11:05 am
Ralph
