Cantrail fitting
#1 Cantrail fitting
Hi, I'm trying to find out how the Cantrail is fixed on my 2 plus 2. It seems as though it uses self tap screws through the seal retainer on the quarter light.
Is this correct and if so what size / type of screws are used?
Thanks for your help
Tim
Tim
they go under the seal and through the retainer. No 4 panheads just be careful on the length.
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
I just had to replace some of my screws because the lower cant rail got pulled off the screws after a burly MoT mechanic sat in the car.
The original No. 4's had become too small in the fixing holes.
I replaced them with No. 6 x 3/4".
S1 4.2 FHC 1966
S1 4.2 FHC 1966
Ok, I have the Cantrail fitted and am now struggling with the rubber quarter light seal. Does any body gave a great idea how to squeeze this in. I'm currently trying with a little water based lubricant and a spatula from the kitchen.
I could really do with a close up of a fitted seal to make sure I have this the correct way round.
All help appreciated
Tim
Tim
fitting the rubber is just time consuming. Personally I pushed the lower edge into the metal retainer and then eased the top edge into the trim with a very blunt / rounded screwdriver. I just inched my way round but yes it takes ages.
1964 FHC 4.2
We used to use P-80 temporary rubber lubricate to fit the grips on motorbikes.
http://www.ipcol.com/pdfs/P80_Flyer_12.pdf
Warren
S1 FHC 4.2 OSB
Warren
S1 FHC 4.2 OSB
Tim when looking at the lower edge of the retainer, the lip of the rubber points up.tim wood wrote:Ok, I have the Cantrail fitted and am now struggling with the rubber quarter light seal. Does any body gave a great idea how to squeeze this in. I'm currently trying with a little water based lubricant and a spatula from the kitchen.
Tim
Angus
61 OTS 875047
61 OTS 875047
thanks Angus but I am really unclear on this.
if I fit so that the lip of the rubber points inward towards the centre of the window is that correct ? or is it so that the lip points towards the bodywork.
I hope im not too confusing?
tim
tim
towards the centre of the window. (well put!)
61 OTS 875047
61 OTS 875047
Tim,
Not much help for you, but I'm glad to hear that I wasn't the only one who found this a tiresome task. I commented elsewhere on the forum that the base of the original seal was foam filled, which made it more compliant to press into the dovetail. The replacement seals all seem to be solid rubber. Even after a couple of years mine haven't deformed sufficiently to give a rain tight seal.
Nick
Nick
1965 S1 FHC
Thanks to all - especially Angus. More time in the garage needed.
As they say "if the job was easy anyone would do it"
Tim
Tim
