#1 Oil leak advice
Posted: Wed Jan 08, 2014 6:13 pm
by Arbington
Hi all
Before I rush into this could anyone advise where the oil leak may be from on the attached pic?
It looks almost like it could be from the head gasket but I can't see it being that. There's a stud behind the distributor which the oil is possibly running down.
Doesn't seem to be the cam cover or timing cover.
It's a 1968 4.2 series 1.5
Posted: Wed Jan 08, 2014 6:17 pm
by 1954Etype
Have got copper washers on those studs?
Posted: Wed Jan 08, 2014 7:47 pm
by FLYV
I had the same problem.I had there copper washers but it was still leaking,then I used same style nuts as used on cam cowers and it is no more leaking.
Posted: Wed Jan 08, 2014 8:26 pm
by Arbington
you are right chaps. There are no copper washers fitted to these underside studs.
Posted: Thu Jan 09, 2014 12:19 pm
by ChrisC
sadly thats normal. I vaguely recall that the stud goes through the head and sits in a small well of oil so eventually the oil works its way down the thread. Its hard to clean out in situ but I tend to use some stud stealant when I fit them.
To be fair mine still leaks so I just keep wiping it clean. A copper washer will help. Same for the other side...
Posted: Fri Jan 10, 2014 9:01 am
ChrisC wrote: A copper washer will help. Same for the other side...
Sandwich the copper washer between the head and an normal steel one.
Posted: Fri Jan 10, 2014 1:48 pm
by Moeregaard
You can also use AN-365 nuts to prevent oil from sneaking past the threads. These nuts have a fiber insert that is more resistant to heat than those with the nylon insert. They're available from any aircraft supplier and cost about the same as the hardware-store stuff.
Posted: Fri Jan 10, 2014 5:02 pm
by 64etype
SELOC brand washers should also do the trick.
