Jockey wheel bearing
andrewh
#1 Jockey wheel bearing
Post by andrewh » Sun Jan 19, 2014 5:36 pm
I am just preparing my drive belt tensioner, jockey wheel, for refitting and I am wondering whether they cause any problems at all? I detect a little play in the bearing, which looks on a preliminary glance to be non serviceable and would like To deal with this now if its likely to be a problem.
1962 3.8 Series One FHC
Dave K
Post by Dave K » Sun Jan 19, 2014 6:09 pm
Don't fit it is my advice they are a pain. Use the dynamo or alternator to tension the belt instead.
Because the belts I bought from the usuals are rubbish they stretch in certain points which means the pulley goes back and forth and ended up nearly wearing a hole through my bottom rad hose.
Moeregaard
Post by Moeregaard » Sun Jan 19, 2014 6:14 pm
The jockey pulley uses a sealed double-race ball bearing. When I was overhauling the mechanical bits on my early 4.2, back in 1991, I very carefully pried the front cover off of the pulley, repacked the bearings with lithium grease, and reinstalled the cover. I staked it with a small centre punch in several places to retain it. It gave me no trouble over the next several years, but if you can eliminate it entirely it'll be one less thing to cause a problem.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
andrewh
Post by andrewh » Sun Jan 19, 2014 6:15 pm
Ah. Right I wasn't expecting that. Anyone else? Thanks Dave
andrewh
Post by andrewh » Sun Jan 19, 2014 8:07 pm
Thanks Mark as well. I will give this serious consideration, I guess most other cars do not have this contraption so it must be fine to eliminate it.
paulsco
Post by paulsco » Sun Jan 19, 2014 9:13 pm
It's distant memory now, but when I was rebuilding my Jaguar 340 (same pulley) I managed to get a replacement bearing from an ordinary roller bearing supplier. I simply got the bearing number off the side of the bearing.
You might be even able to search using the number on-line.
andrewh
Post by andrewh » Sun Jan 19, 2014 9:29 pm
Thanks Paul. Will take a look tomorrow. Cheers
Dave K
Post by Dave K » Sun Jan 19, 2014 9:59 pm
paulsco wrote:It's distant memory now, but when I was rebuilding my Jaguar 340 (same pulley) I managed to get a replacement bearing from an ordinary roller bearing supplier. I simply got the bearing number off the side of the bearing.
The bearings are easy to get, when I rebuilt my car I got the number off the old bearing and contacted BSL who got me a new one.
Thats a tip to anyone restoring their cars don't go to the usuals for bearings they load them up on cost, BSL or any bearing supplier can supply bearings for all cars.
andrewh
Post by andrewh » Sun Jan 19, 2014 10:10 pm
Ok thanks. How does it come out. Is it just pressed out or is there a cap that needs to come off first?
1954Etype
Post by 1954Etype » Sun Jan 19, 2014 10:14 pm
Took mine off as well.
Angus 67 FHC 1E33656
61 OTS 875047
Post by Heuer » Sun Jan 19, 2014 10:28 pm
Got rid of mine as well.
andrewh
Post by andrewh » Sun Jan 19, 2014 10:39 pm
Sounding like that could be the way to go. Thanks guys
