#1 3.8 engine, correct clutch housing?
Posted: Sat Feb 08, 2014 8:32 am
Good morning guys,
i have a problem with the setting of starter, flywheel an d clutch housing and hope to get help from you.
A similar problem was discussed in an older thread but I'm not sure, what to do.
It is a full restoration of a 3.8 from 64. After mounting the engine I made the first attempt to start and there was only one metallic noise which sounds not good.
When I tried this further times, you only could here a click in the solenoid and nothing else.
At the end the starter (lucas/Bendix, first one...) was a little bit overheated and it seems, that it was fix with the flywheel. I made the starter free and disassembled it.
Now I'm wondering what is not correct and what to do. I know that it is important to work with a correct setting consisting of flywheel, starter and bellhousing.
But sorry and it annoys me, that i did not check the setting exactly and made a starting attempt to turn the engine before installing it.
First I checked the flywheel on the basis of photos when it was assembled. It looks like the 3.8 flywheel be comparing the photo in another topic, where there is the 3.8 on the right and the 4.2 on the left side. Another advice for this is the number on the flywheel which corresponds with the engine-number. Therefore it should be suitable with the 3.8 engine and the right one. I think it has 104 teeth then.
I don't know, if there are two different flywheels for the 3.8 are existing.
Somebody told me, that the problem will be the clutch housing which changes from 3.8 to 4.2 and perhaps a second time to series 2 and later cars. I don't know if this is correct, but I decided now to put off the complete engine and look for the correct clutch housing.
So, my question is now how to find the correct one. I also have to say, that the gearbox and the clutch housing were bought in seperate parts a series 2 syncro box (all 4-gear syncro boxes are equal?) and was mounted from a gear box specialist. He connected the box with the housing, too. No idea what sort of clutch housing it is. All parts fit well together and nothing pointed out that anything could be wrong.
Does anybpdy know, how one can see, which clutch housing is the right one when looking for a replacement? I think there are no signs or marks on them. The only advice I could find is, that the hosings from the later ones (series 2 and xj-saloons) don't have the little windows to see the flywheel.
Hope, that somebody has an idea,
Martin
Martin
