I have begun the refurbishing of my series 2 FHC and my focus is the front suspension and steering as the car had been in storage for 14 years and all the rubbers are perished. With the rack off it appeared tight and clunky at every revolution. Once stripped the cause became clear.
One tooth only is badly worn. There is a polished look on all the other teeth, but no wear
There is virtually no wear on the rack apart from some marks on the ends where the pinion has scuffed it
I am wondering what options there are for the rebuild of this rack? It is an April 1970 RHD car and I have been offered a second hand pinion if the supplier can find a match for mine. The rest of the rack shows little to no wear consistent with its 60,000 miles so it is a bit strange to see one tooth worn like this. Has anyone seen this kind of wear in a rack or have any suggestions they can share.
Many thanks. Alan
[/img]
