#1 Cant Rail Removal
Posted: Thu Mar 20, 2014 7:48 pm
by Candellara
I really need to replace the roof lining on the car at some point. The panel that the sunvisors affix to removes easily enough but how are the side cant rails removed?
It'll be made more problematic by the very tight fitting roll cage :-(
Posted: Thu Mar 20, 2014 11:00 pm
by Durango2k
Remove rear windows, Remove rubber sealings (outer), detect rusty screws in rubber Container Rail, Remove them, cantrail becomes free.
Horrid.... Somehow.
Carsten
Posted: Fri Mar 21, 2014 8:17 am
by Candellara
Durango2k wrote:Remove rear windows, Remove rubber sealings (outer), detect rusty screws in rubber Container Rail, Remove them, cantrail becomes free.
Horrid.... Somehow.
Carsten
How are the rear windows affixed? I'm assuming the complete unit needs to be removed inc frames etc?
Posted: Fri Mar 21, 2014 8:19 am
by Candellara
Don't worry. Found a write up - looks very simple
Posted: Fri Mar 21, 2014 8:30 am
by Candellara
One thing after a bit of reading that puzzles me. OK, i've worked out how the cant rails are removed and the panel that the sun visors affix to is easily removed but how do you remove the trimmed panel that runs around the outer edge of the roof panel? including the rear section that houses the interior light?
I assume that this is all removed to facilitate correct retrimming?
Posted: Fri Mar 21, 2014 9:49 am
by 1954Etype
Candellara wrote:One thing after a bit of reading that puzzles me. OK, i've worked out how the cant rails are removed and the panel that the sun visors affix to is easily removed but how do you remove the trimmed panel that runs around the outer edge of the roof panel? including the rear section that houses the interior light?
This is going to be hard to explain but....
The roof lining comprises 4 pieces. The trimmed panel at the front, the main roof panel and two long 'curtains'.
The curtains have a rubber tube sewn into their length an this is fed in via the (removed) rear light and pulled to the front. The tube is hidden inside the car as you pull it through.
The two curtains are then joined in the middle of the interior light. The back is interesting as there is a toothed gripper panel screwed on either side of the light. The curtains are tucked into them an then tapped flat (you might have to open them up first though). Good idea is to remove these grippers and clean off the rust as this could mark your new roof lining.
It really is not as hard as it sounds!
Posted: Fri Mar 21, 2014 9:57 am
by Candellara
Yes it's these "curtains" that confuse me. I assumed that the "curtain" panel just unscrewed - obviously not. Has anyone any pictures to try and help visualise this?
Posted: Fri Mar 21, 2014 3:11 pm
by 38E
If this works, you can see here some pics from when I did my own roof lining:-
http://www.jag-lovers.org/snaps/snap_vi ... 1259388852
Posted: Fri Mar 21, 2014 4:47 pm
by Candellara
Thanks Clive
So, how does the material affix onto the headliner surround at the top and bottom. Is it simply glued on it's upper and lower ledge and then tucked around the edges (obscured by the cant rail on it's lower edge)?
#10
Posted: Fri Mar 21, 2014 7:09 pm
Ring Andy at Hutsons who will give you some ideas
#11
Posted: Fri Mar 21, 2014 7:58 pm
by 38E
Candellara wrote:Thanks Clive
The upper edge should be hemmed and have a rubber tube inserted in that hem. (I just used all he original tubes which were still in good shape.) That edge then tucks in behind the fixed metal cantrail panel (but
after the main roof lining is installed). That's what I'm doing in image #2.
Then, I glued a strip of soft 1/8" foam to the metal, then pulled down the wool material and glued just the lower edge only to the window frame surround. The other shots show he finished job.
The joint at the rear should be positioned underneath the dome lamp fixture with a folded edge on the outer piece for neatness.
You don't want to apply any glue between the foam and the material in an exposed area- the material just stretches over the foam and the foam gives it all a smooth appearance.
None of this is actually very difficult. It just requires thinking about a bit before you go ahead and do it.
#12
Posted: Sat Mar 22, 2014 8:54 am
by osgii
#13
Posted: Sat Mar 22, 2014 7:00 pm
by Candellara
Thanks Guys!
All very very helpful
Jason
