chrisvine wrote:David, Chris,
Thanks for the responses. As the cracks are on the upper surface, I was hoping that if it was possible to repair, it could be done without dismantling.
One suggestion that might work was a low viscosity clear acrylic UV adhesive which would be drawn into the cracks by capillary action. Chris
The cracks are all the way through the acrylic so no amount of polish or surface treatment will fix them. The cracks are too fine for capillary action of anything like an adhesive and show up IMO. They show because of air getting in and altering the refractive index causing internal reflection/diffusion of light that I don't think anything can fix 'after the fact'. Try bending a transparent plastic ruler until it gets the same type of cracking well before it actually snaps. I don't think there's much you can do.
However, the emblems on E-type hub caps are the same part as far as I can tell by inspecting the centre section. How you'd effect a transplant is a different matter but if you find a clean hub cap that could be your source for a correct tint badge. I suppose swapping the cracked one to the hub cap would be no disadvantage as far few people will see those close up compared to the horn push.
