#1 Plug Caps for Electronic Ignition
Posted: Sun Mar 23, 2014 8:10 pm
by SEJohnson95
Richard's S1 4.2 FHC has the 123 electronic ignition system installed that has suppressed leads and caps instead of the Champion "bow-ties" that would have originally come with it. He's planning on upgrading the 3.8 FHC in a similar way, I was wondering if there's any way of retaining the Champion plug caps for the originality factor? Can the internals be modified?
Posted: Sun Mar 23, 2014 9:31 pm
Modern Champion 'Bow Ties' are suppressed. Also you don't necessarily need suppressed cables and plug caps - one or other will do. The only thing I have found that is affected by unsuppressed plug caps/leads is the EDIS/Megajolt system and possibly, though never confirmed, SatNav and mobile phones. Radio's are a different matter of course!
Posted: Sun Mar 23, 2014 11:12 pm
by SEJohnson95
Speaking from memory David as I don't have the car to hand!
I think it's just the leads anyway
Posted: Sun Mar 23, 2014 11:26 pm
by SEJohnson95
Heuer wrote:Modern Champion 'Bow Ties' are suppressed. Also you don't necessarily need suppressed cables and plug caps - one or other will do. The only thing I have found that is affected by unsuppressed plug caps/leads is the EDIS/Megajolt system and possibly, though never confirmed, SatNav and mobile phones. Radio's are a different matter of course!
So, just to clarify a few things, Could you buy a set of original bow ties (which I'm assuming to be unsuppressed) and use them with the suppressed leads? Am I right in saying suppressed plugs
and leads would indeed work, but would just be unnecessary ?
Posted: Mon Mar 24, 2014 12:33 am
by PeterCrespin
All the white badge Bakelite bow ties are suppressed. There's a small slug of carbon between the base of the HT lead screw and the plug top clip.
Posted: Mon Mar 24, 2014 10:17 am
by SEJohnson95
I think the only real issue is making the connections successfully and reliably, either between copper leads and a plugin style distributor cap, or between suppressed leads and Champion caps. Anyone got any ideas?
Posted: Mon Mar 24, 2014 10:45 am
The Champion 'Bow Tie' WCX 600 plug caps have a screw thread which bites into the centre conductor - easy and reliable:
http://tinyurl.com/ndbp4hv
The leads deteriorate after time anyway so simply buy a set of un-suppresed copper leads (or an appropriate total length) and a set of dizzy connectors:
http://tinyurl.com/q72uq6r and
http://tinyurl.com/opzkxar (if you need them. All available from the Green Spark Company.
Posted: Fri Jun 06, 2014 5:57 pm
by mouton
FWIW Ray Livingston recommended I use suppressed wires with the Champion plug caps -- I reproduced the original plug loom for use with his EDIS system. Not sure they are required, but I can confirm that they work just fine with the EDIS/Megajolt system.
Jerry
#9 Re: Plug Caps for Electronic Ignition
Posted: Sat Jun 07, 2014 7:40 am
by KingRichard
I have the 123/TUNE together with the Rob Beere High Performance Ignition Lead And Separator Kit.
Works great. Also installed NGK's BPR5ES to make the list complete.
Richard van den Brand
SEJohnson95 wrote:Richard's S1 4.2 FHC has the 123 electronic ignition system installed that has suppressed leads and caps instead of the Champion "bow-ties" that would have originally come with it. He's planning on upgrading the 3.8 FHC in a similar way, I was wondering if there's any way of retaining the Champion plug caps for the originality factor? Can the internals be modified?
#10
Posted: Wed Jun 25, 2014 9:45 am
by Malc
Have just come across this HT lead separator on Ebay - comes apart to fit the leads. Looks like a good alternative to Rob Breere's one.
http://www.ebay.co.uk/itm/231266296365? ... 1423.l2649
Anyone know anything about it?
#11
Posted: Wed Jun 25, 2014 11:16 am
by kingzetts
?75?!
I made my own separator strip for free. Cut a strip of hardwood off a scrap plank I had lying around, drilled 6 holes in it to suit the HT lead diameter, bent a couple of offcut strips of thin stainless into brackets to fit on the cam cover bolts, screwed the wood to the brackets, bit of yacht varnish - works fine, looks fine.
