Rear hub bearing
vee eight
#1 Rear hub bearing
Post by vee eight » Fri Apr 04, 2014 1:17 pm
Hi All,
Has anybody had a problem with the metal cap that goes into the hole in the rear hub where you grease the rear wheel bearing. Last year I noticed it was missing and replaced it with a new one. It fitted in quite tightly but I have just come to grease the bearings and it is missing again. Any ideas?
Is there any pressure build up that is pushing it out or any other reasons?
This is a series1 4.2.
Thanks Phil
Post by christopher storey » Fri Apr 04, 2014 1:53 pm
Phil : you have identified the problem .If too much grease is pumped in there is insufficient airspace left and when it heats up it blows the cap off. I always drill a small ( 1.5 or 2 mm ) hole in the cap which helps to reduce the chance of this happening . I believe the original caps had such a hole, but modern replacements often do not
Simonpfhc
Post by Simonpfhc » Fri Apr 04, 2014 4:44 pm
I recently ordered a pair from SNG and they arrived with holes in ;-)
Cheers.
62 3.8 FHC
91 Porsche 928GT
vee eight
Post by vee eight » Fri Apr 04, 2014 5:53 pm
Thanks Christopher & Simon.
Mine did not have a hole in the top and that must be why they have been ejected from the hub.
Going to order some new ones and get out my 2 mm drill if the do not have a hole in the top.
Cheers Phil
