#1 S2 Headlamp Flasher
Posted: Fri Apr 04, 2014 4:50 pm
by iani
Having got all my other electrics working I still can't figure out how I am supposed to flash my headlights. I believe it is by pulling on the indicator switch but this sounds the horn, as does pushing the switch towards the column. I have tried the main/dip switch but it does nothing unless the lights are on obviously. Do I have a fault or am I missing something here?
Ian
Posted: Fri Apr 04, 2014 5:13 pm
by Heuer
You have a fault. Pulling the indicator stalk towards you should flash the lights. Horn should work from the horn push. Check the wiring on the indicator switch.
Posted: Fri Apr 04, 2014 5:28 pm
by iani
My horn should work by pushing the indicator stalk towards the column, this is what the handbook says, this is an S2.
by Simon P
Heuer wrote:Horn should work from the horn push
Not on an S2. The horn push is purely decorative...
Posted: Fri Apr 04, 2014 5:32 pm
by Heuer
Missed that bit! Still a problem with the switch wiring I reckon.
Posted: Fri Apr 04, 2014 6:14 pm
by chrisvine
For S2:
Pushing the end of the indicator stalk towards the column activates the horn: Purple/Black wire is earthed completing the low current relay circuit & therefore activating the relay
Pulling the indicator stalk toward you flashes the main beam: connecting Blue/Yellow wire to Brown
Posted: Fri Apr 04, 2014 6:58 pm
by iani
Thanks, I'll take a look at the wiring.
Ian
