Bolt measurements
gmunro
#1 Bolt measurements
Post by gmunro » Mon Apr 07, 2014 4:40 pm
Hi. I'm trying to find out how to interpret bolt/screw measurements from the Jaguar Parts Catalogue, e.g. UFB 131/26R or UFS 131/6R. I'm guessing that one must be the diameter of the bolt and the other the length but advice would be greatly appreciated.
Many thanks and kind regards,
George
Post by Heuer » Mon Apr 07, 2014 5:22 pm
All available in the Forum Knowledge Base:
Jaguar Nuts, Bolts and Fasteners specs: https://dl.dropboxusercontent.com/u/849 ... teners.pdf
Jaguar Grommets and plugs profiles: https://dl.dropboxusercontent.com/u/849 ... ommets.pdf
Jaguar S3 rubber seal profiles: https://dl.dropboxusercontent.com/u/849 ... ofiles.pdf
gmunro
Post by gmunro » Mon Apr 07, 2014 7:28 pm
David - many thanks indeed. The information is perfect.
Can you advise exactly what the difference is between a bolt and a setscrew? I have two measurements as follows -
UFB 131/26R and
UFS 131/6R
From your sheets I can work out the bolt/setscrew dimensions/length etc but I cannot work out the difference between a bolt and a setscrew.
Once again, many thanks and kind regards,
George
Dave K
Post by Dave K » Mon Apr 07, 2014 9:06 pm
A setscrew has a thread the whole length of the shank right up to the head, where a bolt has thread up to a certain length of the shank.
gmunro
Post by gmunro » Tue Apr 08, 2014 6:31 am
David - once again, many thanks for your advice and assistance in this.
Kind regards,
George
