2+2 fuel pump
#1 2+2 fuel pump
My car has anon stanard fuel pump (jap) tested the pressure 5lbs plus probably why the front carby floods so what do I replace it with click ..click or electronic...WAZZA
Electronic SU works superbly. The recently revised submersible pump from SNGB is good if you have a 3.8. You may also want to fit a Filter King and set the pressure to about 3psi: http://etypeuk.com/forum/viewtopic.php?t=164
norman m. macleod
#3 2 + 2 Fuel Pump
Warren,
Even the SU pumps average about 4 psi, whether Click-click or electronic. The SU carburettors prefer around 2 psi feed pressure. The answer is to fit a combined fuel filter/regulator in place of the existing filter. Filter King make an excellent adjustable device that is easy to fit. There is an excellent post on this topic by the Forum Administrator David (Heuer) Jones....look it up. I have one fitted to my Series 1 2 + 2.....
Norman
Perth, Western Australia
Norman
1967 S1 2+2
norman m. macleod
#4 2 + 2 Fuel Pump
Hi David,
You beat me to the draw......! But, a 3.8 2+2.....?
Best regards,
Norman.
Best regards,
Norman.
1967 S1 2+2
#5 2+2 fuel pump
amazing 4 replies in 20 minutes nice to see you're keeping up the standards thankyou gentlemen........WAZZA
