#1 Plug chop after run
Posted: Sun Apr 20, 2014 3:13 am
Nice run today.
What are people's opinions on the tune of the car?
http://www.projectetype.com/images/4.2_ ... 4_2014.jpg
Posted: Sun Apr 20, 2014 6:43 am
by christopher storey
My opinion is - you are well overdue for new plugs !
Posted: Sun Apr 20, 2014 7:59 am
christopher storey wrote:My opinion is - you are well overdue for new plugs !
They're about 12 months old and have covered about 600 miles.
Do you think they're lean, rich, about right?
Posted: Sun Apr 20, 2014 8:13 am
Well, I was actually being serious. These plugs - look at the bodies and the washers - are in quite a state for such a low usage . Maybe it is an aberration caused by the lens, but the plug on the left appears to have a centre electrode which is eroded on the right hand side, and the centre plug is the same with in addition some erosion of the outer electrode . The gaps also look very wide , even if you are running electronic ignition . As far as colour is concerned, with modern unleaded fuels it is very difficult to deduce anything from them unless they are either very weak ( blistered ceramics etc ) or very rich ( everything sooty ) . Also, a plug chop has to be done by shutting off immediately after a full throttle run of several seconds . Going home after a run and then pulling the plugs will not really tell you anything
Posted: Sun Apr 20, 2014 9:51 am
christopher storey wrote: Also, a plug chop has to be done by shutting off immediately after a full throttle
Yep that's how I do it too. I agree, the gaps are set wide as I have an EDIS unit on the car.
Any one have any comments on the tune state? Are the front 2 too lean or is the back one too rich?
Posted: Sun Apr 20, 2014 10:20 am
by Heuer
After a lot of trial and error with the EDIS I set the gaps at .030". Anything larger produced no appreciable difference in performance and I could not be sure it would cause problems under high load/poor fuel/altitude etc. For the cost I would swap the plugs anyway and avoid anything involving rare earth metals
