harmonic balancer 2+2 '67
#1 harmonic balancer 2+2 '67
just got my balancer back after rebu shing but the timing marks are gone question is are they square with the inside keyway or do I have to put the stick down the plug hole and guess.......WAZZA
#2 harmonic balancer
Looking at the balancer off the '67 coupe I'm restoring, it appears that 0 degrees is directly above the center of the keyway in the balancer. Ten (10) degrees is .630" to its left. I measured this by placing a ruler over the center of the keyway to the outer edge where the marks were, and then what I approximated was the rear point halfway around the circumference. I was unable to measure that rear point with complete accuracy - it's only eyeballed, but I think reasonably close. Hope this is helpful.
1967 E Type coupe
1968 E Type OTS
2007 XKR
1968 E Type OTS
2007 XKR
Just how can the timing marks be gone if this is the correct damper ? They are etched into the periphery of the outer part of the damper
