#1 Clutch and exhaust questions V12 2+2
Posted: Mon May 05, 2014 10:53 pm
I've started playing around with my new car, trying to get it up and running after it's near 10 year layup and whilst I do have it running I have a couple of issues/question please.
1. The clutch isn't disengaging, when the pedal is pressed the slave cylinder seems ok and is pushing the arm into the bell housing and an inch or so but it isn't opening the clutch. Anyone know how much movement there should be on the slave cylinder? If the clutch is seized, any tips on freeing it up? I did turn the car over in first with the clutch down and it jumped forward.
2. The o/s downpipe on the exhaust is split so needs a new one, I have taken the system off and then undid the 8 bolts holding the downpipe to the manifold but it doesn't seem to want to budge, what is the best way of getting it out please?
3. Fuel pump - the car is running but not awfully well, it doesn't want to rev up and I suspected the fuel supply. I think only one side of the pump is pumping as I disconnected the wire on one end and there was no clicking noise, I then reconnected the wire and disconnected the other one and it started clicking. Does this sound like I have a fault on the pump and would this result in low fuel pressure/flow which would cause problems?
