#1 Running very rich (3 x su's)
Posted: Tue May 06, 2014 9:18 am
Dear all
My car is running v. rich at the moment. The end of last year I allowed someone to start the car and they pulled out the choke out further than normal. I have had this problem since. What I've done is as follows.
Check float levels (all ok) checked points gap and static timing. Removed the dashpots and reset the jets (all to 75 thou). Check the operation of the choke linkage and its as it should be. Jets move when cable is pulled and return to the correct position when cable is returned. Dashpots not sticking. Slow running set with a carb sync.
The problem is with all 6 plugs so what Have I missed or could check.
Many thanks for any advice or tips.
Keith
Keith
