Spare tyre size
vipergts
#1 Spare tyre size
Post by vipergts » Fri May 09, 2014 9:24 pm
Will a 205/70/15 fit in the spare wheel well of a S1 E?
S1 4.2 Roadster in Resale Red
andrewh
Post by andrewh » Fri May 09, 2014 9:36 pm
Good question. One which I am considering too. Did you not put a spare Avon in the 4.2 Lee?
1962 3.8 Series One FHC
#3 Re: Spare tyre size
Post by PeterCrespin » Fri May 09, 2014 11:21 pm
vipergts wrote:Will a 205/70/15 fit in the spare wheel well of a S1 E?
No
#4 Re: Spare tyre size
Post by PeterCrespin » Fri May 09, 2014 11:25 pm
No, although in an OTS who cares if the boot board is a bit high under the trim? Depending on brand and whether brand new or part worn it can also get very tight diameter-wise, not just widthways.
I think it's OK in an S3. Lard-arse looks have their advantages... :twisted:
Joe Burghard
#5 Spare tire size
Post by Joe Burghard » Fri May 09, 2014 11:48 pm
I have a 205/65/15 spare tire in my '63 FHC. It fits fine, a little snug but not a problem to drop in and center over the fastener hub.
Joe Burghard, '63 E FHC
vipergts
Post by vipergts » Sat May 10, 2014 9:09 am
OK thanks Guys
Andrew....No I had to fit the next size down in the CR6ZZ as a spare
I'm taking them off blue and getting XWX for it. Don't think I can handle the pain of the chips with the Avons....making me cry
44DHR
Post by 44DHR » Sat May 10, 2014 3:32 pm
As Pete says - No.
That is if you have it on a rim, but the 205/70/15 tyre on its own will fit.
Our rims are 6.5 inches, so this makes it not possible. When we do our long European tours we carry a bare 205/70/15 in the spare wheel well and fill it full of spares and tools we need, including tyre weld. Being empty, you can fit a surprising number of parts inside it.
The car's main tyres are only a couple of years old and on the premise that unless it was a major failure, punctures can usually be fixed, at least we have a matching spare in the event of a major failure. We tend to be travelling with a group of friends, so in the event this did happen out in the wilds, we have means to get to a tyre fitter.
regards,
Dave Rose
1967 Series 1 4.2 FHC
#8 Re: Spare tyre size
Post by abowie » Mon May 12, 2014 8:22 am
No
Or in my experience yes, and on a 6 1/2" MWS rim too. I did have to lathe up an extension piece for the big screw that holds it in place.
#9 Re: Spare tyre size
Post by PeterCrespin » Tue May 13, 2014 1:42 am
abowie wrote:Or in my experience yes, and on a 6 1/2" MWS rim too. I did have to lathe up an extension piece for the big screw that holds it in place.
Before answering I tried a 205/70 on a 6" Minilite in the boot of the 62 and the 70 and it fit neither. Both cars have their original boot bodywork.
It was the spare I had used fine on the S3 OTS but barely squeezed under the inner wing panel on the right was a bugger to extract between there and the tank flange. It came closer to fitting in the 70 but more importantly, in both the 62 and 70 it was too high at the back so that board was too high. I'm not saying you couldn't drive round with the wheel in position but I'd be surprised if the wheel actually fitted with the boards flush. It would be interesting to know if the 'It fits' cars had replacement boot floors?
#10 Re: Spare tyre size
Post by abowie » Sun May 18, 2014 3:12 am
PeterCrespin wrote: It would be interesting to know if the 'It fits' cars had replacement boot floors?
I think they are original but in a 50 year old car...
