#1 Fitting Petronix Electronic Ignition to a DMBZ6 Dizzy
Posted: Sat May 17, 2014 6:06 pm
Hi Everyone
I decided that it was about time I fitted the Petronix Electronic Ignition kit to my E's dizzy.
The original set-up had only the positive lead going to the coil via an insulated post on the side of the dizzy body. I removed this and fitted the rubber cone through the hole, which allowed both the positve and negative leads exit the dizzy.
My problem is that the exit point is below the base plate and so the wires have to come up through it to get to the electronics mounted on top. The old positive lead had all it's insulation rubbed away at the point where it emerged from the base plate and some genius had wrapped that bit in black insulating tape.
There are two gaps in the base plate where the wires can come up through but I'm a bit worried that when the vacuum/centrifugal advance mechs act on the plate it will swing round and squeeze or worse short the positive wire.
Has anyone else come across this problem before?
I could drill a new hole in the dizzy body above the base plate but this seems a bit drastic.
Alan
Alan
