It works fine, although I can sometimes feel a slight hesitation while driving, as if there is a short ignition failure. Therefore, I have 2 questions :
1. I can wobble the rotor arm slightly (about 1-2 mm) from left to right (I mean from counterclockwise to clockwise). It's not the rotor arm itself that wobbles, it's the cam. Is that normal ? Should that cam not be firmly fixed onto the engine ? A worn out axis ?
2. There is a vacuum advance unit on it, connected to the (Stromberg) carbs. But this unit does not have a timing adjuster screw on the other side. Can it work well without the screw ?
Thanks gentlemen !
