Thinner belt to alternator is about 10mm wide. Thicker one to water pump about 13mm.
Alternator is a 60amp Lucas, but can't see part number on it.
And here is the drive down to the water pump:
Now various questions come along here and follow on from having had a couple of hot experiences. Driving home after buying the car it got hot and we ended up by-passing the Otter switch to keep fans on all the time, and kept cool after that. Then the other day for our first proper run out again got hot. Let her cool down then checked things.
The radiator was quite cool and on removing the radiator cap we had to top up with several kettle fulls of water. Yet the expansion tank was at half measure.
Again today I checked her over and needed about a litre to top up the radiator.
There's no obvious sign of a leak, and the oil isn't looking sludged up with oil/water mix.
1 Do we have an incorrect pump and alternator? (The engine was rebuilt 4000 miles but many years ago by a reputable company, but don't know of subsequent work)
2 Could it be an air lock, or lack of water that was stopping the Otter switch working?
3 The expansion tank cap has 15 on it, presumably meaning 15 lbs. Now it should be 7 for this engine/car. Could this be a cause of problems?
Any advice or suggestions will be most appreciated, and, no, I've not resorted to breaking an egg into the radiator yet to stop leaks!
