I'm pleased to see that this has brought up wider issues, here's one I made earlier .............
When fitting new rad hoses recently I replaced the steel bend for a new one from SNGB sold as C16999 together with the elbow-to-pump hose C12630 and elbow-to-radiator hose C15099.
So far so good.
However, the steel bend is actually way too long on both sides of the 90? bend and protrudes way too far into the hoses - it ends up touching (on my car) the radiator stub at the front end, and I had to take an inch off the front end of the pump-to-elbow hose before it looked even half-right.
Furthermore the ends of both the hoses that take the steel elbow are actually a good 1/8" bigger diameter than they need to be (they're a sloppy fit) and so when you tighten up the hose clamps (more than you ought to need to) you end up with a yawning gap (well, bit of an exaggeration OK) between the hose and the elbow - you can see this on the third picture, below.
It fits, it doesn't leak, it'll last just as long as correctly-fitting parts, but it's naff.
Being a simple one-plane-only bend I
could just get this knocked up in stainless at a suitable diameter, with correct lengths, and solve the problem - which is only a question of aesthetics, BUT which are of course vital for a Jag-owner's well-being - but am I missing something here ?
Anyone else had this problem - is it a manufacturing error, with the customary 'nobody has ever complained about this before', or something else ?
