I was surprised to find this valve loose in behind the
pressure plate
There was no indication of any oil pressure problems. It was fine both at idle and at higher revs. I presume its a pressure relief valve ?
Its obvious where it came from, but it's not quite as obvious which way round it should be
I'm hoping someone can shed some light on how it should go back in and also whether I should use some sort of Loctite product to help prevent it coming out again. Also is there a possibility of some underlying reason for it to have come out in the first place?
Many thanks, Alan.
