rev counter generator stopped
tim wood
#1 rev counter generator stopped
Post by tim wood » Sun Jul 01, 2012 4:36 pm
so my rev counter stopped and on testing the generator is not producing current. Strange I think - so I remove it and find that the bronze bush has moved back in the casting and thus the dog isnt engaged. looking further the bush is a finger push fit in the housing and can easily by moved with a finger (when hot )
Anyone come across this before?
not sure how i can refix this bush - any thoughts welcome
(i suppose i can just buy a new one but what a cost!)
regards
Tim
daverawle
Post by daverawle » Sun Jul 01, 2012 5:16 pm
It's common. I drilled through the housing and most of the way into the bush then pressed in a steel pin. I used locking compound on the pin though doubt it will stick to the sintered bush.
1963 OTS
tim wood
Post by tim wood » Tue Jul 03, 2012 8:27 pm
Thanks Dave, helpful reply. Just completed this mod and can't see how it can fail to work.
Cost - nothing , just how I like it!
Tim
Durango2k
Post by Durango2k » Wed Mar 16, 2016 8:56 pm
How far is the bush allowed to stick out in the cam direction ?
Flush ? Or 1-2 mm out ?
Mine is fully loose as well...how deep should it sit in the alloy case ?
Carsten
tim wood
Post by tim wood » Thu Mar 17, 2016 6:08 pm
Think I did mine flush
Tim
