#1 3.8 Diff Output Shaft - Help needed Please
Posted: Thu Sep 11, 2014 12:51 pm
I have had to remove the IRS to tackle an oil leak from the LHS diff output shaft oil seal on my 1962 3.8
There is no obvious reason for the leak, the oil seal seems in good order and is only 12 months old, the body of the output flange onto which the seal lip seats is smooth and although there is a shiny ring there is no grooving. I'm pretty sure the leak is not from between the output shaft bearing housing and the diff body where there is an O-ring, but from the oil seal itself. So to some extent I'm grasping at straws.
I have two questions to which I am struggling to find an answer in the usual sources;
First, what is the torque specification for the large nut holding the diff output flange onto the drive shaft?
Second, under this nut there is a thick dished washer. Should the washer be located with the domed face facing inwards towards the output flange body, or outwards towards the backside of the nut?
And finally your opinions please on whether oil can seep along the splines on the output shaft and weep out from under the nut/washer combo mentioned above, so is it worth putting some sealant on the splines?
Thanks in advance
Thanks in advance
