#1 Correct fuel hoses
Posted: Sat Sep 13, 2014 5:54 pm
Hi everybody,
May I ask if the black hose in the picture below is correct for a fuel line?
The fuel hose upstream the bowl (yellowish) seems to be original, while the black one between the bowl and the filter is different.
I am concerned because that black hose has small cracks and needs to be changed.
Also these black hoses apparently have been put when the PO installed a cylinder filled with catalyst balls down the fuel filter.
My engine is a 3.8, year 1964. I understand from what I read here that apparently it is not necessary to have such catalyst for using unleaded fuel as the valve seats are already hard enough. If so, it would be useless but would not do any harm either and could stay there. Anybody can confirm?
