#1 Route of starter motor cable
Posted: Sat Oct 25, 2014 11:14 am
by paulsco
I?m puzzling over the route of the starter motor cable on my late 65 FHC.
I have done a search and the advice is that it goes along the bottom frame rail.
This seems a bit of a torturous route for the cable; the connector at the side of the bulkhead is more at the level of the top rail and I cannot see in any picture I have studied, any trace of it on the bottom rail.
Could somebody please confirm its detailed route and perhaps point me in the direction of some photos.
Thanks,
Posted: Sat Oct 25, 2014 1:04 pm
by Moeregaard
hi, Paul. The starter cable comes off the terminal at the left side of the car, runs along the underside of the outer/upper frame rail, continues under the upper member of the picture frame, and then continues along the inner/upper right-hand rail on its way to the starter. This is the route take on both of my Series One E-Types.
Posted: Sat Oct 25, 2014 1:23 pm
by paulsco
Hi Mark,
You have confirmed where I thought it should run.
Thank you,
Posted: Tue Oct 28, 2014 5:43 am
by BAHADORI
Hello
here is some pictures.
Best
Jacques
