#1 Number of teeth on flywheel
Posted: Thu Oct 30, 2014 12:35 pm
All sources say that the 4.2 liter should use a 133 toothed flywheel. Part number C18517
I am in need of a flywheel and have found one locally here in Norway with 132 teeth. I've counted them several times. Apparently it's from a XK 120 / 140 or Mk 7.
Simple question : will the 132 toothed flywheel work on the 4.2 liter E-type ?
Or is there a difference in overall diameter, hence difference in the radial placement of the starter motor pinion. Hence "clash" in use.
Next question : I know of a XJ6 2.8 liter which can sell it's flywheel, does anyone know how many teeth that has (I fear it has 104, which of course doesn't help me)
