#1 Tightening Spinner?
Posted: Thu Nov 13, 2014 11:00 pm
by Sjmmarsh
I had to remove a wire wheel as the valve stuck when checking the tyre pressure. Removing the spinner (3 short eared version) took much bashing with the hammer - it rotated halfway round before it started to move easily.
The manual doesn't give much advice on how much to tighten the spinner by - I gave it 5 hard whacks with the hammer and stopped as it didn't seem to be tightening on the last blow.
Is that tight enough, or do I need to hit it some more? It does seem a brutal way to put a wheel on....
Posted: Thu Nov 13, 2014 11:58 pm
by Heuer
220lb/ft is the recommended figure. Three whacks with the hammer should do it. If you are using repro spinners all bets are off.
#3 Re: Tightening Spinner?
Posted: Fri Nov 14, 2014 7:09 am
Sjmmarsh wrote: it rotated halfway round before it started to move easily.
About right; maybe a little loose.
