Hi guys I'm new to this forum and needed some advice.
I am restoring my first E-Type Series 1.5 2+2, with a 4.2 litre engine.
It has a 4-speed gearbox but keeps popping out of gear 2 & 4 which are the 2 gears in the down position.
I have just got the car on the road and have realised this on the test drive.
It goes into 2 & 4 gear fine but when I take my foot off the peddle it pops out.
Has anyone had this problem before or can any give me some advice?
2+2 GEARBOX ISSUES - ADVICE NEEDED
#2
It may be as simple as the boot on the gearshift being a bit too bulky and pushing it back up.
Yes, I had this problem, albeit on a saloon with the 4 synchro box, and it was indeed the rubber gaiter which was causing the problem
Moeregaard
#4
Jumping out of gear is often caused by excessive wear in the shift linkages, but as the others have suggested I would first check that the rubber gaither isn't pushing it out of gear. Out of curiosity, how many miles are on the gearbox?
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
Thanks for your replies, I'll check them all out. I have done 95K miles Moeregaard
Thanks guys for all your help. Me and my dad took out the centre console and drove the car and it was fine. I believe it was the rubber gater!
