Low compression
stephen.
#1 Low compression
Post by stephen. » Wed Mar 04, 2009 12:24 pm
Hi all, I have one cylinder ( number 5 ) that is running very weak. Number 6 is just on the weak side of OK. I have done a compression check, 140 and with oil on the rings 150 psi. I dont think this is low enough for a valve to be not seating enough / burnt to give me a weak mixture. I think the problem lies with an air leak in the inlet manifold gasket.
I know 140 is low with 9:1 pistons but I am reluctant to remove the head if I dont have to and will not strip and rebore / re ring the engine as with so many other projects on the go, I wont ever get it back together.
What do you think ? A valve or a manifold :( :( gasket ?
Post by Heuer » Wed Mar 04, 2009 4:18 pm
Go for the easy option - change the manifold gasket! Before that you might want to check the front carb to ensure the piston is moving freely, the needle is centred, is not damaged and the mixture is set correctly.
Post by christopher storey » Wed Mar 04, 2009 4:40 pm
Stephen; one way to check for a manifold leak is, with the engine hot and idling, to squirt a flammable solvent such as wd40 at the joins between manifold and head, and carbs and manifold. If any change in engine running occurs, this is a sure indication of a leak
Also it's worth checking your servo hoses etc
Larry Wade
#4 low compression
Post by Larry Wade » Thu Mar 05, 2009 5:52 am
Hi Stephen,
I strongly recommend that you get a leak down test done before anything else. That will tell you if you have a leak and where it is going.
Larry
Larry Wade
62 OTS 877842
La Canada, California, USA
Moeregaard
Post by Moeregaard » Thu Mar 05, 2009 2:05 pm
I'm with Larry. This one smells like a head-gasket problem.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
