My original starter motor has started to play up - namely not disengaging correctly
Any thoughts on lightweight starters and best place to buy?
Best Lightweight Starter for 4.2
Candellara
Topic author - Posts: 328
#1 Best Lightweight Starter for 4.2
69 4.2 FHC ex Race Car
F-Type V8S
Mercedes 300SL 107
F-Type V8S
Mercedes 300SL 107
I got mine from Moss-Europe, you'd need to call them to make sure you get the right model for your car, ?158 IIRC and it works great.
Ian
Ian
Jaguar - 1970 S2 2+2 (sold), 1970 S2 FHC, X150 5.0 XKR, x250 XF x2 (sold) XF SportBrake
1968 Triumph GT6 Mk1
Nippondenso: viewtopic.php?t=6668
That's an alternator David :DHeuer wrote:Nippondenso: viewtopic.php?t=6668
Candellara
Two questions:
What are the variants for a S2 4.2?
Also, is this possible to change without removing carbs?
F-Type V8S
Mercedes 300SL 107
F-Type V8S
Mercedes 300SL 107
Yes starter can be removed without removing carbs... Steve
I think the starter is the same for all the 4.2 engines.Candellara wrote:Two questions:
Some of the generic high torque starters have an adjustable mounting plate that can be rotated and locked in place. This is a nice feature so that you can get the angle of the starter right relative to the side of the block.
My series 1.5 has a nice hole with plate in the footwell that allows some access to the 2 bolts at the back of the starter. Not sure if this feature is there on series 2 cars but it will make getting the bottom bolt out a lot easier if it is. It's tight in there but you should manage with an appropriate amount of swearing and fiddling.
Replacing the 2 mounting bolts with hex headed screws has the advantage that you can lock the screw positively onto the tool which may make insertion easier.
