#1 Lucas model 85 turn indicator rebuild question
Posted: Sun Apr 12, 2015 10:50 am
by BT7
I was able to locate a new nylon spring and a rivet and have that part of the assembly back together. However, when I loosened the two slotted screws that hold the plastic electrical connector to the aluminum bracket and then started to separate the two pieces a small bright copper colored spring popped out. I have all of the remaining springs in their proper places, but I don't know where the spring that popped out goes and I don't understand what function it serves. Can anyone help?
Thank you!
Lin
Here is a link to two photos that show the spring in question and the turn indicator. If anyone can tell me where the little spring fits I would appreciate it!
https://www.flickr.com/photos/valve-cha ... 882768722/
Lin
Posted: Mon Apr 13, 2015 3:23 pm
by JimmyS
Hi Lin,
If memory serves I think it may sit on the spigot that locates the copper disc, above the spring shown on the right in your photograph. This is compressed when the headlights are flashed.
I would take my indicator switch apart again to check, but there's a danger a spring may fly out!
Jim
Posted: Mon Apr 13, 2015 5:15 pm
by paulsco
Hi Lin,
I think Jim is right; is there a corresponding hole in the plastic?
The Mk2 indicator switch is slightly different from the E-Type.
I have recently done the same thing on my E Type indicator switch, but unfortunately can't remember where the springs go.
I have however a very out of focus picture of the spring sitting on top of the copper disk, which sort of confirms its position.
#4 Lucas model 85 turn indicator rebuild question
Posted: Tue Apr 14, 2015 5:06 am
by BT7
Perfect. I do recall that there is small "post" in the center of the disc on which the spring would sit. I will take it apart tomorrow and give it a try. Thank you Jim and Paul!
I will report back on success or failure.
Lin
#5 Post subject: Lucas Model 85 turn indicator
Posted: Wed Apr 15, 2015 12:12 am
by BT7
I am pleased to report that my turn indicator is back together and seems to be functioning properly. I won't know for sure until I have the car back together, but thanks to Jim and Paul I believe I now have all of the components in the proper place.
THANKS!
Lin
