Brake Bleeding - Handbrake off
johnben
#1 Brake Bleeding - Handbrake off
Post by johnben » Mon Apr 13, 2015 5:47 am
Hi Folks
I am sure some will be shaking their heads at my lack of knowledge but I cannot work out why it is necessary to release the handbrake when bleeding brakes as instructed by the Haynes Manual. What is the reason?
Post by christopher storey » Mon Apr 13, 2015 9:23 am
There is no reason for it . The Haynes manual is wrong .
Post by abowie » Mon Apr 13, 2015 9:54 am
christopher storey wrote: The Haynes manual is wrong .
Ermagerd heresy! You will burn in hell!!!
Post by abowie » Mon Apr 13, 2015 9:55 am
My suspicion is that Haynes manuals are constructed, to a degree, from generic text. Maybe some handbrakes are hydraulic...
johnney
Post by johnney » Mon Apr 13, 2015 10:22 am
The manual assumes whoever is bleeding the brakes at the rear is positioned under the car as the rear brakes are inboard and that maybe you have the car on ramps or similar. It's a matter of safety, of course you would not want it to roll off and flatten you!
johnney
1968 FHC series 1
1E21862
Post by Gfhug » Mon Apr 13, 2015 12:53 pm
If you've not started the bleeding here is a useful post on an easy way of doing it:
viewtopic.php?t=6273
johnben
Post by johnben » Tue Apr 14, 2015 5:42 am
johnney wrote:The manual assumes whoever is bleeding the brakes at the rear is positioned under the car as the rear brakes are inboard and that maybe you have the car on ramps or similar. It's a matter of safety, of course you would not want it to roll off and flatten you!
Thanks for the replies.
johnney I think you misread the post, the situation you describe is what the Haynes Manual recommends.
johnney
Post by johnney » Wed Apr 15, 2015 6:45 am
:D
johnney
1968 FHC series 1
1E21862
