Can anyone advise on the best/correct type of gasket for the fuel tank sump?
When I removed the sump to clean it out it had a black rubber/neoprene seal but the replacement I ordered was a fibre washer, which refused to seal no matter how much I tightened it. The faces of the tank and sump looked in good condition.
Mine is a Feb 1962 car chassis 885626
Fuel tank sump gasket problems
Original was cork or fibre but you need to make sure all surfaces are clean and true. Hylomar might help.
ALAN COCHRANE
I feel your pain. I had the same problem last year. I also ordered two different types of seal from SNGB, both of which deformed when the sump was.tightened.
I ended up making my own from, as David says- cork gasket. I made the seal much bigger than the original. This meant that the diameter counteracted the deformation problem.
I also ordered a new seal and foam packing ring that fits around it as an insurance policy. But still no leaks to date, fingers crossed.
+1 for the Blue Hylomar by the way.
Alan
Alan
Alan Cochrane
