#1 Best Lightweight Starter for 4.2
Posted: Fri May 29, 2015 4:07 pm
by Candellara
My original starter motor has started to play up - namely not disengaging correctly
Any thoughts on lightweight starters and best place to buy?
Posted: Fri May 29, 2015 4:21 pm
by iani
I got mine from Moss-Europe, you'd need to call them to make sure you get the right model for your car, ?158 IIRC and it works great.
Ian
Posted: Fri May 29, 2015 4:23 pm
by Heuer
Posted: Fri May 29, 2015 4:25 pm
by iani
Heuer wrote:Nippondenso: viewtopic.php?t=6668
That's an alternator David :D
Posted: Fri May 29, 2015 4:49 pm
by Candellara
Two questions:
What are the variants for a S2 4.2?
Also, is this possible to change without removing carbs?
Posted: Fri May 29, 2015 5:40 pm
Yes starter can be removed without removing carbs... Steve
Posted: Fri May 29, 2015 11:01 pm
Candellara wrote:Two questions:
I think the starter is the same for all the 4.2 engines.
Some of the generic high torque starters have an adjustable mounting plate that can be rotated and locked in place. This is a nice feature so that you can get the angle of the starter right relative to the side of the block.
My series 1.5 has a nice hole with plate in the footwell that allows some access to the 2 bolts at the back of the starter. Not sure if this feature is there on series 2 cars but it will make getting the bottom bolt out a lot easier if it is. It's tight in there but you should manage with an appropriate amount of swearing and fiddling.
Replacing the 2 mounting bolts with hex headed screws has the advantage that you can lock the screw positively onto the tool which may make insertion easier.
