123/tune distributor curves
Alty Ian
#1 123/tune distributor curves
Post by Alty Ian » Thu Jun 25, 2015 6:20 pm
Can anyone recommend a suitable curve to start off on a rebuilt engine that is being run for the first time?
A starting point? I could set up 2 curves as I have a switchable one that allows adjustments while the engine is running as well.
Bit of a novice on this stuff so an idiots guide would be appreciated :oops:
iani
Post by iani » Thu Jun 25, 2015 6:31 pm
Look in the knowledge-base Ian, under Technical Info you will find KingRichard's curves, alternatively, PM me your email address and I'll send you his latest ones.
Ian
Jaguar - 1970 S2 2+2 (sold), 1970 S2 FHC, X150 5.0 XKR, x250 XF x2 (sold) XF SportBrake
1968 Triumph GT6 Mk1
Alty Ian
Post by Alty Ian » Fri Jun 26, 2015 9:25 pm
Thanks very much Ian for the curves, the latest ones are very similar arent they. Sent you an email as well.
