#1 Front camber shims.
Posted: Sun Jun 28, 2015 5:26 am
I'm refreshing the front suspension on my S1 coupe. Essentially because it has scrubbed the left front tyre badly and steers like a bag of s#$t.
So I treated it to new tyres and I took it in for a wheel alignment. They didn't do it though because both the top and bottom ball joints were loose. So I've replaced them, the shockers, the tie rod ends and the upper wishbone bushes. I did the front wheel bearings as well for good measure.
When I took the right upper wishbone off there were 5 shims at the front and only 3 at the rear. On the left side there were 6 at the front and 3 at the rear.
This surprised me; I've only ever seen the same number of shims front and rear. Is this correct, or an indication of previous miss-assembly?
Having finished I don't want to put the bonnet back on; it looks so cool!
