My series 2 fhc has poorly fitted doors and bonnet and is taking water like titanic when its washed. I will be fixing this soon as the car is about to get roadworthy again.
In order to get the doors fitting well I intend to remove all of the rubber seal to be sure that there is not due to rubber seals.
I have tried to bring the doors closer to body by adjusting the doorlock on b pillar but there is not enough adjustment. I suspect it is because of wrong rubber seals.
After reading up on the forum it seems like this is a problem for more than myself.
Can anyone advise on a supplier that have a kit with the correct seals? I intend to change them all as I dont thrust the company that did the restoration at some point in time. Almost everything they have touch or looked at is crap.
proper rubber seal kit and door adjustment
Quattrofrank
Topic author - Posts: 327
#2
COH Baines seem to be the supplier of choice http://www.coh-baines.co.uk/
