#1 Bonnet/top hose clearance
Posted: Fri Aug 14, 2015 1:12 pm
by david muir
Folks, does anyone have a rough estimate of the clearance between the top hose and the bonnet?..........mine seems to have closed up!-hose has left witness mark on bonnet underside........can't imagine that the bonnet has dropped at the front(been perfect for years).
Posted: Fri Aug 14, 2015 3:54 pm
Hi Dale. ..If it's touching then something is not right.....have a close look at the front frame that support the bonnet for any signs of movement,bending, cracks etc.....has the car been in a garage and someone accidently jacked up under the frame instead of the picture frame.. Steve
Posted: Fri Aug 14, 2015 4:00 pm
Check also the engine mountings for tearing/stretching . Someone may have jacked under the sump with unfortunate results
#4 bonnet/top hose etc
Posted: Fri Aug 14, 2015 5:11 pm
by david muir
Car has only had me working on it for last 15 years. I put blue tack on bonnet (aprrox. 3/16" thick) and there was a slight impression mark from hose(new). Slackened clips and twisted hose 'round a bit' and retried.........impression was less but still a 'ghost' ! Obviously clearance is marginal. Have stuck some thin foam on bonnet and will keep an eye out.
Posted: Fri Aug 14, 2015 7:06 pm
Hi Dave. ...don't leave it and wait.....A dent in the bonnet will be a nightmare...check out all the points mentioned Steve
