fan blade serie one
Polse7317
#1 fan blade serie one
Post by Polse7317 » Thu Mar 24, 2016 2:19 pm
I'd like to change only the fan blade on my serie 1 , anyone knows where i can find a more efficiency blade without changing the motor?
Post by Heuer » Thu Mar 24, 2016 3:23 pm
You should not do that. A bigger fan will cause the motor to run slower and over heat or burn out. Consider fitting a Coolcat fan/motor along with the upgraded thermo-switch (a very reliable Mitsubishi unit actually). Details here: http://www.coolcatcorp.com/category/CS.html and shipping is very quick. You can also buy them in the UK from Ken Verity.
Polse7317
Post by Polse7317 » Thu Mar 24, 2016 4:26 pm
Hello David, thank's for your quick respons, i'll buy a coolcat which seems to be fitted in the serie one shroud without any modification.
I don't find " ken verity " on google ...have you more details about ?
cactusman
#4 Fan
Post by cactusman » Thu Mar 24, 2016 5:25 pm
David is right. Fit a coolkat fan. I did. Works fine. It can be done without removing the radiator or cowling...does take some patience but the coolkat comes with a mount that fits straight on the bracket where the old Lucas fan was....job done.. I bought mine direct from the USA. Delivery took about ten days.
Durango2k
Post by Durango2k » Thu Mar 24, 2016 6:22 pm
Maybe a lawn mower shop can help.... Only jokin'
Carsten
Post by Heuer » Thu Mar 24, 2016 6:37 pm
Ken does not have a web site and can only be paid by cash or cheque. Maybe better to order it direct from Coolcat? You can use their web site and, as someone else says, delivery is very fast.
If you want to contact Ken his number is: +44 1709 838352
neil4444
Post by neil4444 » Thu Mar 24, 2016 6:43 pm
Fosseway also do a fan, although it requires replacement of the cowling too. Vey pleased with mine.
http://www.fossewayperformance.co.uk/e- ... oling-fan/
Neil
1962 S1 OTS
1967 S1 FHC
Polse7317
Post by Polse7317 » Thu Mar 24, 2016 7:57 pm
I have ordered a coolcat one , i'll post some photos of fitting when i'll have it :wink:
cactusman
#9 Fan
Post by cactusman » Thu Mar 24, 2016 8:12 pm
Takes about an hour..
