#1 trouble understanding the torsion tie plate removal
Posted: Sat Aug 22, 2015 10:54 pm
Just in the process of taking out the engine/clutch/gearbox assembly and am now at the tie plate removal stage, which has me a little perplexed. Perhaps someone can help my understanding.
From the service manual :
"Remove the nuts securing the torsion bar reaction tie plate on each side and tap the bolts back flush with the face of the tie plate. With the aid of a helper, place a lever between the head of the bolt just released and the torsion bar. Exert pressure on the bolt head to release the tension on the upper bolt. Remove the nut and tap the upper bolt back flush with the face of the tie plate. Withdraw the bolts securing the tie plate on each side to the body underframe channels through the side members. Tap the tie plate off the four bolts."
So, if I take this piece by piece
The tie plate has 6 bolts, 3 each side. 2 on tie face plate and 1 connecting to the body underframe. So far so good.
1. remove the nuts securing the torsion bar reaction plate on each side.
- That is the nuts on the four bolts, 2 left, 2 right.
2. tap the bolts back flush with the face of the tie plate
- Tap these bolts back in the holes, so their ends are flush with the plate.
so far, so good. 4 nuts off, and bolts tapped back flush.#
3. With the aid of a helper, place a lever between the head of the bolt just released and the torsion bar.
- hmm I've just released no bolts, only 4 nuts and tapped the bolts back. which bolt is meant. The one just above the torsion bar entering the tie plate I assume...
Which direction should be levered? down? couple of options here.
Bolt
Lever
Torsion Bar
4. Exert pressure on the bolt head to release the tension on the upper bolt.
- OK. Once step 3 is worked out, that sounds easy enough.
5. Remove the nut and tap the upper bolt back flush with the face of the tie plate.
- Strange, I thought that had already been done in step 1 and 2
6. Withdraw the bolts securing the tie plate on each side to the body underframe channels through the side members.
- OK. Not much clearance, but looks possible.
7. Tap the tie plate off the four bolts.
Might be a challenge, as it doesn't look like it will move in that direction.
I do wonder, if the torsion tie plate has been put back together by a PO with the bolts going the opposite way.
From the front of the car the bolts go towards the back. Bolt being at the front, nut on the rear end.
Are these instructions assuming the car is on the ground and not on a lift?
I'm sure I'm having a dumb moment here, but would appreciate any input before I have a torsion bar whacking me before I know what's coming.
I did look at the Front suspension piece in the manuals and the thread on "Torsion bar preload?" but am not any wiser. Didn't really want to be taking the full Front suspension apart as well as removing the engine.
Bolt
Lever
Torsion Bar
